unsure if audacity will record teleseminar
r5pheenix
Post by r5pheenix » Thu Feb 18, 2010 5:06 pm
Greetings,
I am nearly finished migrating into Win7 Pro in the 64-bit flavor.
I am 'beginner' status with audacity - had good luck with editing/splicing/exporting on XPsp3 32-bit platform, but had not tried to record.
Have latest LAME.
Only using integrated sound - no card.
Unable to find a way to get settings to allow recording of a teleseminar.
What have I missed ?
What do I need to check or verify ?
Thanks !
Re: unsure if audacity will record teleseminar
Post by kozikowski » Fri Feb 19, 2010 3:43 am
<<<recording of a teleseminar.>>>
Need to know a lot more about that. Is this special software that allows you to participate in the seminar, or it a simple web page that you sit with a cup of tea and watch? Describe the steps you need to perform to see the seminar.
r5pheenix
Post by r5pheenix » Sat Feb 20, 2010 7:21 am
Non-restricted access - opening either one page, or onto a second web page, then click on "listen" button - these are audio not video.
Not sure of "new" file type, but these will not respond to "right-click to download", where I was able to simply download in earlier months. I guess this is some new way to protect files, but have the same problem with Youtube stuff.
-also-
saw one demo (Youtube, I think) that displayed a button for selecting source - do not have a button like that in my install.
Discovering the same situation whether it is real-time or visiting it as a replay.
Post by steve » Sun Feb 21, 2010 4:01 pm
To record sounds playing on your computer you should ideally set the default recording input to Stereo Mix by going to the Windows Control Panel and setting it there.
See here: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
r5pheenix
Post by r5pheenix » Sun Feb 21, 2010 10:23 pm
Thanks very much, guys,
The comment on rt-clk to find disabled devices was quite helpful, and managed to expose that the only device possible to add was CD Audio.
I now show Aux-ready, Microphone-ready, Microphone-default, CD Audio-ready, and Line-In-ready.
No drivers would accept being updated, and windoze claims it is totally happy that everything is up to date and "working properly".
These questions started with a Lenovo box using XPsp3 over dual-core Athlon that did not survive Win 7 due to mobo and memory and power mgmt issues.
I just launched an HP dual quad Xeon workstation.
Looks like I need to buy a sound card since neither o/s nor hardware can get me up to "sound mix" ??
I guess that would explain why audacity can't show a button to select since there is no device to recognize ?
Post by kozikowski » Sun Feb 21, 2010 10:37 pm
Well. As the version of Windows goes up, the hostility to recording internet audio goes up. Last known, Mix-Out was a "Hidden" or Obsolete" tool and you had to go digging for it.
Did you go down all the threads in that instruction page? This is not a new problem.
http://forum.audacityteam.org/viewtopic ... 870#p17870
Post by kozikowski » Sun Feb 21, 2010 10:39 pm
That's only the free way to do it. If nothing else works, you can use Total Recorder or other Windows software package. I've used my license for years.
