using Presonus Firebox, can't get input 2 to work
BeatleWho
Re: using Presonus Firebox, can't get input 2 to work
Post by BeatleWho » Tue Dec 01, 2009 10:14 am
Document02 wrote:
Bradlee wrote:I just talked with Presonus tech support and they said that the Firebox can work only with ASIO Drivers.
The firebox is stated to work on windows, delivered with windows drivers, so you can safely bet that the tech support is just trying to get away whatever way they can with their lousy windows drivers. (I had issues with a couple of other windows based softweres working with WDM driver). Concerning the number of inputs, I wouldn't know if this is a limitation of the firebox or in the way windows deals with sound...
That said, I record in stereo and split the 1/2 inputs as already described with good results. You will not loose sound quality doing this, but be careful to save before splitting I noticed some crashed when playing around with stero/mono split and merge functions.
Additional tip, unless you really want to record in 96kHz, install the latest drivers but keep the older firmware of the firebox (I took them quite some time to get a firmware that could record in 96kHz, even though the firebox as always been advertised as a 24bits/96kHz interface), as the new firmware creates a higher noise level when recording (more info in the presonus forums)
Do you have some version numbers on that firmware and where to find it? That way we'll know what shipped in our Fireboxes....what we really WANT....and what to avoid....
Duane
http://www.myspace.com/t60player
http://www.myspace.com/duanemantick
also on Facebook and god knows where else that might change overnight
BeatleWho
Post by BeatleWho » Tue Dec 01, 2009 10:15 am
Document02 wrote:During the install of the newer drivers they ask you if you want to udate the firmware.
If you don't know, the firmware rollback is available on presonus site
http://www.presonus.com/faqdownloads/Fi ... llback.exe
FYI, this page currently comes back with a "not found" error......
Duane
