Vst plug ins dont work
JLrecords
Post by JLrecords » Mon Jan 25, 2010 4:56 am
hello im using a windows xp and i have audacity 1.3 beta and i keep trying to put the vst plug ins for more effects and i did the whole procedure and it doesnt work and everytime i try to download lame for the site it says 403 forbidden and its not my firewall blocking it any help?
JLrecords
Re: Vst plug ins dont work
Post by JLrecords » Mon Jan 25, 2010 5:11 am
i tried downloading a file i downloaded before i think it was laspda and it had about 60+ more effects and i cant find it anymore it had flange and everything im looking for that effect
Post by steve » Mon Jan 25, 2010 7:56 pm
I've moved your posts as they were in the Audacity 1.2 part of the forum.
JLrecords wrote:i keep trying to put the vst plug ins for more effects and i did the whole procedure and it doesnt work
Are you setting Audacity to rescan VST's the next time it starts?
Not all VST's are supported. VSTi (instruments) are not supported and some VST effects are not supported.
See here for more help: http://wiki.audacityteam.org/wiki/VST_Plug-ins
JLrecords wrote:i think it was laspda and it had about 60+ more effects and i cant find it anymore
See the "Optional Downloads" section on this page: http://audacityteam.org/download/beta_windows
JLrecords wrote:i try to download lame for the site it says 403 forbidden and its not my firewall blocking it any help?
Follow the directions on this page to the letter: http://audacityteam.org/help/faq?s=inst ... m=lame-mp3
JLrecords
Post by JLrecords » Sun Feb 21, 2010 6:54 am
thanks alot i found those effects gavent downloaded yet ill show u
JLrecords
Post by JLrecords » Wed Feb 24, 2010 2:59 pm
Ok i downloaded LADSPA plug-ins 0.4.15 installer
and i did everything i seen them download and audacity rescanned it yet nothing pops up
Post by steve » Wed Feb 24, 2010 5:48 pm
JLrecords wrote:Ok i downloaded LADSPA plug-ins 0.4.15 installer
Did you "run" the installer?
Those LADSPA plug-ins need to be installed (you will need to have Administrative permissions to install the software)
axltvojamama
Post by axltvojamama » Sun Sep 12, 2010 7:33 am
i installed al of the plug ins and te effects dont appear :( plz help
Post by steve » Sun Sep 12, 2010 2:09 pm
axltvojamama wrote:i installed al of the plug ins and te effects dont appear :( plz help
See other post: http://forum.audacityteam.org/viewtopic ... 68#p102568
