Importing MP3 - file shows as only .09 seconds long???
red7261
Post by red7261 » Tue Jan 19, 2010 5:19 pm
When I import an MP3 file (particularly a 30 minute track) it shows on the audacity window as being only .09 seconds long. And when I play it it's just a quick blip. The image of the file looks normal but the counter says it's really short. What am I doing wrong?
waxcylinder
Re: Importing MP3 - file shows as only .09 seconds long???
Post by waxcylinder » Tue Jan 19, 2010 5:56 pm
You are almost certainly trying to import a file type that Audacity does not support. Audacity Supports WAV, MP3, OGG and FLAC & MP2 in 1.3.[/i]
If this is the case you have two basic options:
1. find and use some converter software to convert your file to a type that Audacity supports
2. play the file in any music software that supports that particular file format and record it in Audacity.
stevethefiddle wrote:There's a free program called SUPER by erightsoft that can convert most media file types. If you can convert the files to WAV files that should fix the problem.
