1st Track Fine, all after are overwhelmed by white noise
Musiclover4522
Post by Musiclover4522 » Sat Jan 16, 2010 6:44 am
Hi I am not new to audacity, just new to the beta, i was amazed of how much better it was until i went to grab something to drink, when i came back to start recording again it was just overwhelmed by white noise, i run my guitar and instruments through a Line 6 UX2, the 1st track records fine, and all other programs work fine, when i turn the overdub feature off it seems to work but i can't record not having that feature on, can you please help me :(
im not sure what you need to know please post i can tell you all :(
Re: 1st Track Fine, all after are overwhelmed by white noise
Post by steve » Sat Jan 16, 2010 4:06 pm
How are you monitoring the recording?
Is your Line6 using USB2 drivers? Are the drivers up to date?
Do you have any other USB devices attached?
Musiclover4522
Post by Musiclover4522 » Sat Jan 16, 2010 6:47 pm
Not sure how but i restarted my computer atleast 6 times, virus scanning and everything, found nothing, Woke up this morning windows update did a small update and it is working fine, i am thinking maybe a driver got updated, but anyways all is well, i appreciate your help steve, thanks for taking the time to view my post :)
Have a wonderful day
Post by kozikowski » Sat Jan 16, 2010 7:28 pm
You can get that by having difficult USB connections. If you have a connection that's just hanging on buy thin threads, the music can succeed or fail with humidity of the room and whether or not it's Thursday.
Unplug and replug each USB connection two or three times and you may need to restart the computer if you do that.
stewart40
Post by stewart40 » Thu Mar 03, 2011 11:22 am
I have been using Audacity and Line 6 UX2 toneport. I am having the exact same problem with white noise. I think its because I have to turn the gain up pretty high to get a reasonably loud sound despite the fact everything everywhere is turned up and phantom power boosts etc are being used. At a low volume the white noise is unhearable and If it could be louder and keep the sound quality it would be great. I am trying Audacity beta this evening and will let you know how I get on.
