lpvmc wrote:In 1.2.6 I need to monitor the levels (see them in the meter)
Oh right, if you don't need to monitor through headphones then that solves a major headache.
The link that I posted is for 1.3.11 alpha. We don't usually recommend alpha versions, but we're making an exception this time because a) the current beta has a known bug that makes it unusable for many people, and b) quite a few of us have been testing it out for a while and it's really good.
The 1.3.11 alpha version does not need "installing" as such. You just extract the contents of the ZIP file onto your computer, then create a shortcut icon from the audacity.exe file to your Desktop. Double clicking the shortcut icon will then launch Audacity.
Before you attempt to run Audacity on the Toshiba, go to the Windows Control Panel and check that you have an audio device enabled for recording. See here for details:
http://wiki.audacityteam.org/index.php? ... ng_devices
