first 3 seconds records fine, then...
....I recently installed Audacity 1.3.x (Beta) on my new pc with a Windows 7 OS....I tried recording and the first three seconds record fine but after that it sounds like it's going through a flanger of some type....I have all my effects turned off and am sending a dry signal...also, when I go to choose an input on the mixer bar I can't there's only four choices, not like audacity 1.2.6 where there was a choice of CD, microphone, stereo, mono, etc....what am I doing wrong?
Re: first 3 seconds records fine, then...
Check that you do not have "software playthrough" selected (Transport menu).robhervey wrote:the first three seconds record fine but after that it sounds like it's going through a flanger of some type
Was that also on the same computer with Windows 7?robhervey wrote:not like audacity 1.2.6 where there was a choice of CD, microphone, stereo, mono, etc
yes it was on the one with the WIndows 7
I don't know what it tis but I can record drum loops and keyboard parts but for some reason, If I record some didjeridoo, the first 3-4 seconds come out fine then after that the signal sounds like it's all flanged out our something,what am I doing wrong? I will post a youtube video demonstrating to clarify
I just posted a video demonstrating my problem on youtube here's a link:
[http://www.youtube.com/watch?v=IwhaK0zHfc0]
thanks
thanks
That is terrific
It's the most dramatic demonstration of "Noise Cancellation" that I've ever seen.
Somewhere in your sound card settings there should be a switch or selection box that allows you switch on/off the noise cancellation. It may be called something different (echo cancellation? noise reduction? ...) so you'll have to have a good look through and switch off all effects so that you can get a "straight" recording.
What is happening is that because Your sound card/Windows sees a constant drone (from the didj) it assumes that it is background noise and is doing a really good job of cutting it out. You have no doubt noticed that when there is a sudden change to the drone (when you take a breath), the sound comes back briefly before it is again cancelled out.
thanks muchly
soI tried to adjust the device settings, updating the drivers, rolling back the drivers and I still can't record how I want to.....there's no button to click on that says "noise reduction, cancellation or anything like that....so what do I do?
If there is no setting for it then you've got a problem. I've seen laptops where there is no setting for it in the actual sound cards interface (from the icon near the time/date) but there has been one hidden away in the Control Panel. Hopefully it is similar on your computer and you will discover it lurking in a dark corner.
By the way, what sort of sound card do you have.
don't know what I did or didn't do but it's recording now....
