exporting after resampling
i have cd+g files on hard drive i want to put on cd-r. the mp3 is sampled in 22khz and power cdg burner is only compatible with 44.1khz. i dont have a problem opening the files dragging and dropping the mp3 into audacity and resampling it to 44.1khz but what do i do next ? do i have to pair it back to a graphics file? where do i send it to and how . hope you can help thank you
Re: exporting after resampling
You need a CD-G editor program to merge the MP3 file with the MCG file.
If you've not got a suitable program it may be worth trying "CDG Editor" from here: http://sourceforge.net/projects/cdgeditor/files/
I've not tried that program, but it's free and open-source so it will cost you nothing to try.
If you want a commercial CD-G editing/burning program, use Google - there are lots of commercial programs readily available.
[Note for "helpful" people wanting to advertise commercial CD-G programs - please don't do it here!
This is the Audacity help forum, not an advertising board for spam]
