Thanks for your interest.
Here is a "picture" of what happens step by step...
http://dl.free.fr/vZ9qtH0Zb
Plugins
Re: Plugins
That plug-in is not the standard "High Pass Filter". That effect applies a high-pass filter that has a variable cut-off frequency controlled by a low frequency oscillator. Is that the effect that you want, or do you just want an ordinary high-pass filter?
The reason that it gives an error is probably because your version of Audacity does not support the use of a comma (,) as a decimal separator.
The current version of Audacity should accept the use of a comma.
To use the effect, either update Audacity, or replace the comma with a dot (.)
I think the current version of Audacity includes a normal low-pass filter and high-pass filter.
Re: Plugins
Hi
Well the ordinary HI/LO pass filter will do...
But I don't see any default filter in my Audacity...
Regards
JL
Regards
JL
Re: Plugins
They are definitely included in the latest version of Audacity that is available here http://wiki.audacityteam.org/index.php? ... tly_Builds
This version also fixes several bugs that were present in earlier versions.
Re: Plugins
I am going to download it again. Maybe some plugins have been suppressed by mistake.
Thanks again
Thanks again
