OK, I take it all back, this is a design decision based on the fact that Audacity can't read your mind.stevethefiddle wrote:If you want to see the current cursor position you can use "Edit menu > Move Cursor > To Selection Start" or "Edit menu > Move Cursor > To Selection End". I know that's not very convenient but you can set a keyboard shortcut.
Coincidentally, I have already set shortcuts for those two commands (<semicolon> and <comma> respectively) since I use them quite often. It never occurred to me
I would therefore recommend to roga that he set shortcuts for those commands and use them to display the cursor at the current zoom level. One keystroke as opposed to scrolling or zooming out and then in.
-- Bill
