adds several seconds
westwind
Post by westwind » Wed Dec 30, 2009 10:33 pm
I use audacity to chop audio files up into shorter segments. I do this by selecting from the beginning to a certain point, then choosing EXPORT SELECTION (under file menu), and repeating this process to chop an hour or so of audio up into tracks of a few minutes each.
I am finding that the saved segments often have a few seconds of audio added on to the end - ie the file being created by export has an end point several seconds past the one I chose. There is no problem with the beginning of tracks - so the extra seconds would appear (wrongly) and the end of one track and then again at the start of the next one.
I didn't seem to have this problem before 1.3.10 beta - so is this a problem with me or with Audacity?
billw58
Re: adds several seconds
Post by billw58 » Wed Dec 30, 2009 10:52 pm
Yes, this is a known bug in 1.3.10 - files exported with Export Selection or Export Multiple are rounded up to the nearest 5 seconds.
Download the lastest 1.3.11 through this page: http://wiki.audacityteam.org/index.php? ... tly_Builds
-- Bill
westwind
Post by westwind » Thu Dec 31, 2009 10:32 am
billw58 wrote:Yes, this is a known bug in 1.3.10 - files exported with Export Selection or Export Multiple are rounded up to the nearest 5 seconds.
-- Bill
Hi, Thanks - downloading 1.3.11 seems to have solved the problem.
aum_shinrikyo
Post by aum_shinrikyo » Sat Jan 02, 2010 11:15 pm
-- Bill
I am having the same problem as the fellow you answered with this response. I downloaded the file linked to "unicode release" under the windows binaries section and opened as instructed on the page and still have the extra time added to the end of the files.
p.s. when I opened the 'about audacity' under help it still says it is 1.3.10, am I not downloading the correct file?
billw58
Post by billw58 » Sat Jan 02, 2010 11:28 pm
When I hover my mouse over the windows unicode link on that page I see a link to 1.3.11-alpha.
-- Bill
Post by steve » Sun Jan 03, 2010 2:48 am
aum_shinrikyo wrote:p.s. when I opened the 'about audacity' under help it still says it is 1.3.10, am I not downloading the correct file?
You probably have downloaded the correct file but not "installed" it correctly.
Actually, it doesn't need "installing" - just extract the contents of the file somewhere on your computer, then make a Desktop shortcut to the audacity.exe file that is in the extracted folder. When you launch Audacity from that shortcut and check Help it should say "Audacity 1.3.11 alpha (Unicode)" or something like that.
aum_shinrikyo
Post by aum_shinrikyo » Sun Jan 03, 2010 6:57 am
stevethefiddle wrote:You probably have downloaded the correct file but not "installed" it correctly.
That is how I had done it the first time. I did not make a shortcut though I opened directly from the program in the folder. I re-downloaded though, and the .11 version has worked perfectly.
Thank you.
