NO SOUND OR PLAYBACK
scate51
Post by scate51 » Tue Dec 29, 2009 5:06 pm
i just got a ITUT-201SVR for xmas and am trying to record my albums to my laptop. First off it sounds like the turntable is ripping my record apart and there is no sound and no playback at all. It looks like it is downloading but there is no sound. I am using Windows XP on my Dell Latitude.
Re: NO SOUND OR PLAYBACK
Post by steve » Tue Dec 29, 2009 5:31 pm
First thing to do is check the stylus and check that all the packaging has been removed.
waxcylinder
Post by waxcylinder » Wed Dec 30, 2009 12:14 pm
As Steve says - and ...
When you plug in a USB device like this your computer hands over control of all sound services to the USB device - both input and output. Since your USB TT doesn't have a set of speakers, you then don't get any sound from the computer (not even the normal computer sounds).
All you need to do is to get your O/S and Audacity to retarget the sound output onto your computer's on-board soundcard. In Windows use Control Panel > Sounds and Audio Devices > Audio > Sound Playback (I don't know the MAC equivalent) - in Audacity use Edit > Preferences > Audio I/O > Playback Device - you may need to close and restart Audacity for the change to take effect.
Also see this page in the Wiki: http://wiki.audacityteam.org/index.php? ... turntables
