when applying a chain to a series of files, the process stops for the metadata information for each OGG file being exported. the point of the chains is that it can be done to a series of files automatically without user interference. there needs to be a setting to turn off the request for data.
Also, on my machine, the program crashes after I hit OK on the screen that prompts for the data.
metadata editor for 1.3.4 disturbs chain processing
Re: metadata editor for 1.3.4 disturbs chain processing
How strange.... the first time I tried it, it prompted me for the first file only, then processed the rest without prompting. Tried it again and now it prompts for every file.
There appears to be a setting for it in Preferences->Batch but it doesn't seem to work
I'm not getting the crash problem though. Can you post your chain commands (and parameters) - it could be something there causing the crash.
I'm using Windows XP Audacity 1.3.4
[EDIT] - very very strange. I tried the preset chain examples, then tried applying chain commands to a project (rather than files) and finally tried my test chain on files (again) - and it's working without prompting for metadata now.
Steve, did you reset Audacity in between those two tests? Sometimes you have to reset Audacity in order for preferences changes to take effect.
I have the show metadata editor unchecked.
It still opens when I apply the chain to export an OGG.
After I hit ok on the editor, Audacity 1.3.4 crashes. Here is the error report from windows:
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="audacity.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="audacity.exe" SIZE="9252864" CHECKSUM="0x86C70239" BIN_FILE_VERSION="1.3.4.0" BIN_PRODUCT_VERSION="1.3.4.0" PRODUCT_VERSION="1,3,4,0" FILE_DESCRIPTION="Audacity®, the Free, Cross-Platform Sound Editor" COMPANY_NAME="The Audacity Team" PRODUCT_NAME="Audacity®" FILE_VERSION="1,3,4,0" ORIGINAL_FILENAME="Audacity.exe" INTERNAL_NAME="Audacity" LEGAL_COPYRIGHT="Copyright © 2007. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8DC3F8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.3.4.0" UPTO_BIN_PRODUCT_VERSION="1.3.4.0" LINK_DATE="11/11/2007 23:36:32" UPTO_LINK_DATE="11/11/2007 23:36:32" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="unins000.exe" SIZE="695577" CHECKSUM="0x9C2AF9D4" BIN_FILE_VERSION="51.49.0.0" BIN_PRODUCT_VERSION="51.49.0.0" PRODUCT_VERSION="0.0.0.0" FILE_DESCRIPTION="Setup/Uninstall" COMPANY_NAME="" PRODUCT_NAME="" FILE_VERSION="51.49.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="51.49.0.0" UPTO_BIN_PRODUCT_VERSION="51.49.0.0" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="Plug-Insgverb_1216.dll" SIZE="102400" CHECKSUM="0x11AC7927" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="09/26/2006 00:28:39" UPTO_LINK_DATE="09/26/2006 00:28:39" />
<MATCHING_FILE NAME="Plug-Inshard_limiter_1413.dll" SIZE="98304" CHECKSUM="0xEEC6F149" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="09/26/2006 00:28:40" UPTO_LINK_DATE="09/26/2006 00:28:40" />
<MATCHING_FILE NAME="Plug-Inssc4_1882.dll" SIZE="106496" CHECKSUM="0x1DC325BC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="09/26/2006 00:29:03" UPTO_LINK_DATE="09/26/2006 00:29:03" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="984576" CHECKSUM="0xF0B331F6" BIN_FILE_VERSION="5.1.2600.3119" BIN_PRODUCT_VERSION="5.1.2600.3119" PRODUCT_VERSION="5.1.2600.3119" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.3119 (xpsp_sp2_gdr.070416-1301)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF9293" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.3119" UPTO_BIN_PRODUCT_VERSION="5.1.2600.3119" LINK_DATE="04/16/2007 15:52:53" UPTO_LINK_DATE="04/16/2007 15:52:53" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
<DATABASE>
</EXE>
</EXE>
</DATABASE>
