update 1.3.9 to 1.3.10 - convert files to directories
r.gayler
Post by r.gayler » Sat Dec 05, 2009 10:39 am
Hi,
I use Audacity on Windows XP. I was attempting to install 1.3.10 over 1.3.9 and got some odd error messages
In the directory ... Audacity 1.3 Beta (Unicode)helpmanualskinscommon (and also ... monobook) the installer tried to convert the the pre-exisiting files commonprint.css and iefixes.js to directories and create files called (respectively) 207.css and 207 in those directories, with the file contents being apparently what was in the files that it wanted to convert to directories.
I have just ignored the error messages and left the old versions of the files unchanged.
Ross
Re: update 1.3.9 to 1.3.10 - convert files to directories
Post by steve » Sat Dec 05, 2009 4:47 pm
Find the folder C:Program FilesAudacity 1.3 Beta (Unicode)help and delete it (the "help" folder). Then install Audacity 1.3.10 again.
The developers are aware of this issue (I reported it this morning).
