Can't detect lame_enc.dll on Windows 7
Contact:
Re: Can't detect lame_enc.dll on Windows 7
Post by Gale Andrews » Fri Sep 03, 2010 12:32 am
jacob1919 wrote:i have also same problem so i downloaded this lame_enc.dll file from dll-files.com but it not working plz tell what exactly i do...
Please read the posts above and the links thereon. Please double-check the instructions here to make sure you have no old paths to lame-enc.dll stored in the Audacity settings.
Audacity 1.3 will (mostly) only work with lame_enc.dll compiled by us, so if the above instructions don't work for you, please try these alternative versions of lame_enc.dll:
* http://www.gaclrecords.org.uk/lame_enc-win-3.98.3.zip
* http://lame.buanzo.com.ar/libmp3lame-win-3.98.2.zip
* lame_enc.dll without manifest (this solves most problems which can't otherwise be resolved):
http://www.gaclrecords.org.uk/lame_enc_no_manifest.zip
* As a last resort, a version of lame_enc.dll 3.97 which should work in latest 1.3.x:
http://forum.audacityteam.org/download/file.php?id=824
We do not recommend LAME 3.97 because that version produces distortions unless you use bit rates over 192 kbps.
Green Gorgon
Post by Green Gorgon » Sun Oct 03, 2010 4:51 am
I'm still having trouble getting lame_enc.dll working with 1.3.12. I'm using Windows XP
I've tried using every file listed on this thread (and a few from other places), going through the ritual of telling Audacity where it was and making sure the two lines were deleted in audacity,cfg.
Every single time I get the error "Could not open MP3 encoding library!" The exclamation point is mocking me, I can feel it.
Clearly I'm doing something wrong. Maybe someone can tell me what's up.
Contact:
Post by Gale Andrews » Sun Oct 03, 2010 5:03 pm
Green Gorgon wrote:I'm still having trouble getting lame_enc.dll working with 1.3.12. I'm using Windows XP
Where are you putting lame_enc.dll? It should be automatically detected by Audacity if you place it in:
* Program FilesLame for Audacity
* the Audacity Installation folder
* the Plug-Ins folder inside the Audacity installation folder
Make sure there are no other versions of lame_enc.dll in those places.
Normally there is no problem with the 3.97 lame_enc.dll, even if the others fail. If you wish you could download Dependency Walker, drag the 3.97 lame_enc.dll into it, File > Save the .dwi file and e-mail it to me at
gale_at_audacityteam_dot_org
formatted like a normal e-mail address with _at_ replaced by @ and _dot_ replaced by a period (.). That should show if the 3.97 lame_enc.dll is failing because some library it depends on is missing from your system.
Also if you install the "Lame v3.98.2 for Audacity on Windows.exe" to the expected Program FilesLame for Audacity, you should be able to export using its LAME.exe at the command line. When you export, choose "(external program)" instead of "MP3 files", click "Options", ensure the command reads lame - "%f " then save the file making sure you add the .mp3 extension to the filename.
Contact:
Post by Gale Andrews » Wed Oct 06, 2010 9:43 pm
@Green Gorgon: Thanks for the .dwi file and your message off-list. I'm a bit surprised that 3.97 (htttp://forum.audacityteam.org/download/file.php?id=824) was failing as well. I wouldn't mind seeing the dwi file for that 3.97 if that's possible.
The dwi file you sent indicates your machine seems to be lacking msvcr80.dll, so could you try unzipping this .dll from the attachment and placing it in your Audacity installation folder?
Thanks
msvcr80.zip
(308.99 KiB) Downloaded 271 times
galoshes
Post by galoshes » Sat Jan 22, 2011 11:36 am
I also have a problem with exporting mp3s.
I'm using windows 7 and the beta version of audacity.
I installed a LAME encoder earlier. When I tried to do an export to mp3, I got the message saying that the mp3 encoding library couldn't be opened.
I am also having problems uninstalling the LAME encoder so i can try other versions. In the uninstall area of the control panel, the file doesn't appear. Is there another way to uninstall if the program doesn't appear there?
Contact:
Post by steve » Sat Jan 22, 2011 6:49 pm
galoshes wrote:I installed a LAME encoder earlier. When I tried to do an export to mp3, I got the message saying that the mp3 encoding library couldn't be opened.
Which version of Lame did you install and where did you get it from?
Did you follow the instructions HERE to configure Audacity?
galoshes
Post by galoshes » Sat Jan 22, 2011 8:36 pm
Initially I used a different LAME encoder I believe. I then sent it to recycle bin and downloaded the LAME recommended in the audacity instructions and have the same problem: audicity doesn't recognise mp3 library, doesn't appear in the uninstall area of through the control panel. Is it OK if I simply send it to recycle bin, delete from reclycle bin, then try again with a different encoder?
Contact:
Post by steve » Sun Jan 23, 2011 12:37 am
Yes you can delete it, but then:
Download the ZIP version of Lame from here: http://lame.buanzo.com.ar/
Extract "lame_enc.dll" from the ZIP file into the Audacity 1.3 beta installation folder (should be in "Program Files")
Restart Audacity
Go to "Edit menu > Preferences > Libraries" and click on the "Locate MP3 Library" button and Lame will be automatically detected.
galoshes
Post by galoshes » Sun Jan 23, 2011 2:39 am
Thanks for your help Steve. Got it working. :)
Bridgeboy
Post by Bridgeboy » Sun Feb 20, 2011 1:43 am
The LAME website, http://lame.buanzo.com.ar/, is down for me. Is there a mirror to get the installer? Links just to the dll don't work for me.
