does not find MP3 encoder
dtrivedi
Post by dtrivedi » Fri Nov 27, 2009 10:20 pm
Despite downloading MP3 encoding LAME file, it still gives me a message "cannot locate MP3 encoder' although it has been downloaded in C:/PROGRAMME FILES/Audacity..This happens when I Save as MP3, Any suggestions please, Thanks you, Daksha
Irish
Forum Crew
Re: does not find MP3 encoder
Post by Irish » Fri Nov 27, 2009 10:40 pm
You need to tell Audacity where the Lame library is.
Click on Edit > Preferences, and in the Preferences window click "Libraries".
Click on MP3 Library > Locate, and browse to the folder the Lame library is in. Click OK to store the preference.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Polleke
Post by Polleke » Sun Dec 20, 2009 9:56 pm
I've tried all the steps, including those on the LAME installation page: deleted old libraries, deleted the audaciti.cfg file etc. still it can't find the library.
At last I deleted everything, uninstalled Audacity, removed all directories and started all over. Still it can't find the library... :-(
I haven't got a single clue! Anyone who can help?
OS Win XP SP3, upgrading from 1.3.6 to 1.3.10
Irish
Forum Crew
Post by Irish » Mon Dec 21, 2009 12:01 am
Can you find the Lame library (lame_enc.dll) with Windows Explorer?
Once you've found it, make a note of where it is. Then in the "Locate Lame"window (which you got to by clicking Edit > Preferences > Libraries > MP3 Library Locate) click Browse and go to that location.
Double-click on the lame_enc.dll file, and then click OK in the "Locat e Lame" window.
PO'L
Post by steve » Mon Dec 21, 2009 4:32 am
I find the easiest way is:
Download the ZIP version (for Windows) from this page: http://lame.buanzo.com.ar
Extract the contents of the zip file into your Audacity folder (which is in "Program Files").
Open up Preferences (from the Edit menu) and on the "File Formats" page, click on the "Find Library" button.
Polleke
Post by Polleke » Mon Dec 21, 2009 6:58 pm
I shall be more precise, I was a bit in a hurry yesterday......
By default, the LAME encoder is in c:program fileslame for audacity. So, from within the find library dialog box I go there to find the library, which actually is there. But when I try to load the file, nothing happens. It still says "library not found"
So in Windows Explorer I go to c:documents and settingsownerapplication dataaudacity and open the audacity.cfg file. The above mentioned path is in the file.
I delete the lines (and later the complete cfg file) and start all over. Still no luck.
The FFMPEG loads directly in one try.
To even make it more confusing: I installed 1.3.10 on another computer running XP: no problems....
Post by steve » Mon Dec 21, 2009 7:05 pm
Polleke wrote:By default, the LAME encoder is in c:program fileslame for audacity. So, from within the find library dialog box I go there to find the library, which actually is there. But when I try to load the file, nothing happens. It still says "library not found"
I don't know why but this seems to happen for a small minority of users. In nearly all of those cases, using the ZIP version of Lame instead and putting it in the Audacity program folder (as described in my previous post) does the trick. Give it a go and let us know how you get on. Good luck :)
Polleke
Post by Polleke » Mon Dec 21, 2009 9:02 pm
Thanks a lot Steve, it is working now!
