Tip for compression/distortion problems
deer of the dawn
Post by deer of the dawn » Wed Nov 25, 2009 12:54 pm
I kept having trouble with distortion when using compression. The individual tracks sounded fine, but played together, distortion city. I figured out that it was just too much audio and when I lowered the gain on the individual tracks, the distortion went away.
If you are having problems, reduce the gain on each track and mix at a lower level. When you mix the tracks down you can compensate and bring the volume up to normal using compression on the mix without that nasty distortion! :D
Dell Inspiron 1440/ 4 GB Dual Processor/ Vista/
M-Audio Mobile Pre-USB
Blessings to all.
