I notice the Audacity Manual has a section on Noise Removal and a search of the forum shows several topics that mention NR.
However, after looking thru the Index and Tutorial I can't find anything on NR or how to get into the NR window they show in the Manual.
I want to remove the constant hum on a phone recording.
What's the easiest way to do it in 1.3.9.
How do you do Noise Removal on a phone recording?
waxcylinder
Re: How do you do Noise Removal on a phone recording?
You will two passes at this:
1) Find a short section of the recording which is "silent" apart from the hum and use Noise Removal to Get Noise Profile
2) Select the whole recording - use CTRL-A and then re-use Noise Removal to effect Step 2 - I would start out with the default parameters.
Test - and if ok then home and dry, else Undo the Noise removal and start over agin.
I would strongly recommend exporting a copy of the raw recording as a WAV file before you start. This is your unedited safety copy that you can always go back to if you screw up the editing ....
For a detailed write up, click on the "Tutorials" link at the top of this page.
About half way down that page is a link "Noise Removal for removing steady noise like hum and hiss from all types of audio".
