Hi,
I'm using XP SP2 and Audacity 1.3.9 with Creative Audigy Platinum sound card. I can import audio files and I can record from line-in no problem. However, I cannot record direct from the sound card. I have played WAV files in my other sound programs and Windows Media Player, but when recording it seems there is some sort of loop-back as the recording track in Audacity shows even a simple one ring bell to ring and ring building up to a crescendo.
I only have the line out connected to speakers, all options but Wave are muted in the Play Control and only WAVE is selected in the Recording Control.
Can anyone suggest a solution, please?
Kind regards, Paul
Recording with Audigy Platinum
Pauliebanger
waxcylinder
Re: Recording with Audigy Platinum
Paul,Pauliebanger wrote: it seems there is some sort of loop-back as the recording track in Audacity shows even a simple one ring bell to ring and ring building up to a crescendo.
that's called "feedback".
Go to Edit > Preferences > Recording and uncheck the box that says Software Playthrough ....
Pauliebanger
WC,
Thanks, very succint response! Much appreciated.
It's surprising how easy it is to overlook the basics when panick takes over.http://forum.audacityteam.org/images/ic ... edface.gif
All is calm again.
Peace and love
Paul
All is calm again.
Peace and love
Paul
