waxcylinder
Post
by waxcylinder » Sun Nov 22, 2009 6:13 pm
billw58 wrote:
If no tracks are selected Audacity appears to try to record to all tracks. If the number of channels to be recorded doesn't match the input settings then that error message is technically correct if a bit unhelpful.
If you select one track then press SHIFT + R then it works.
So, should SHIFT + R throw up an error message telling the user to select a track for append-recording rather than throw up that unhelpful error message?
-- Bill
Bill,
curiously I had just independently tried that track selection trick as some further testing and was just about to report back - you beat me to it ...
But yes - a more sensible and informative message would indeed be helpful
- Site Admin
Post
by steve » Sun Nov 22, 2009 7:58 pm
For your information, on Linux, it just records the same thing onto all tracks, as long as you don't try recording a stereo input into a mono track.
