Which audio do I use
mygreygolf
I am running 1.3.X in Windows 7 64 bit. Whis is the best audio - MME High Def or IDT High Def CODEC? Is one any better than the other or should I be using a different audio altogether?
Re: Which audio do I use
Windows 7 has not yet had much real "field testing" for Audacity (or any other application).
I'd suggest that you try both and see which works better.
Is there an option for "direct sound"?
If Audacity is currently working - write down settings (on paper) before you change them - that way you can easily put it right if you mess up.
mygreygolf
Hi! It is a 'direct sound' option. I can't personally hear any difference and since the manual for my computer makes several references to the 'IDT' option, that's what I'll play with.
Thanks!
Thanks!
