MP3 export problem
sda
Re: MP3 export problem
Post by sda » Thu Oct 29, 2009 4:50 pm
K what do I do with the lame that goes with my Nero burning softwawre. Because I did a search one other time and I belive there are lame files found in my Nero and Cakewalk programs?
Thanks
Post by steve » Thu Oct 29, 2009 4:53 pm
Make a note (on paper) of exactly where they are and temporarily rename them (example - lame.dll.bak)
sda
Post by sda » Thu Oct 29, 2009 6:19 pm
K then if Audacity works with them renamed we know whats wrong. Then what do I do with the programs that use the lame files I renamed?
Post by steve » Thu Oct 29, 2009 8:04 pm
One at a time, rename them back to their original file name and hope nothing breaks.
sda
Post by sda » Fri Oct 30, 2009 3:25 pm
Ok, did all that and still nothing. Like I said in one of my first posts I'm running this on my home computer fine, I have all the same programs with lame as the computer at the church, mine works but the churches doesn't. The only thing I came come up with is that the churches computer is NOT hooked up to the internet so the Windows XP that is on it has never had any updates since the machine was built. Would that have something to do with it?
Post by steve » Fri Oct 30, 2009 4:43 pm
sda wrote:so the Windows XP that is on it has never had any updates since the machine was built. Would that have something to do with it?
I guess that's possible. I don't know if anyone has ever tested this version of Lame on anything earlier than XP SP2 ("no-one" has XP pre-SP2 ... oh, except for perhaps you ;) )
Could you have a look to see exactly which version of XP you have there (Right click on "My Computer" and select "Properties > General")
sda
Post by sda » Fri Oct 30, 2009 9:39 pm
Ya I downloaded both SP2, and 3 and will try that. That's probably the thing I can think of.
sda
Post by sda » Sat Oct 31, 2009 3:13 pm
Turns out it did have SP 2 on it. I went ahead and put SP 3 on and that made no difference. I directed Audacity to the lame encoder that I had on my jump drive and it still didn't work. I think this must be a lost cause and I will just stick with what we've been doing. Unless there is someone else out there that has any other ideas.
Thanks for the help,
Shane
Post by steve » Sat Oct 31, 2009 7:23 pm
I'm curious why this computer refuses to play, and it would be good to find a fix, but I'm out of ideas so I've asked someone else to take a look. They will probably post within the next few days if they can think of anything not already covered.
Post by Gale Andrews » Sun Nov 01, 2009 1:35 am
Assuming all other instances of lame_enc.dll have been removed or renamed, initialise audacity.cfg. Do this by exiting Audacity, then open audacity.cfg in a text editor and remove all the content except "NewPrefsInitialized=1" at the top: See:
http://audacityteam.org/wiki/index.php? ... reset_beta
Then put the lame_enc.dll 3.98.2 you got from us inside the folder where Audacity is installed (the one where audacity.exe and the Plug-Ins folder are). Don't go into Preferences browsing. If Audacity asks where LAME is when it's in the installation folder, it isn't going to work.
As a last resort, try this version of lame_enc.dll 3.97 which should work in 1.3.9:
http://forum.audacityteam.org/download/file.php?id=824
Note we do not recommend 3.97 because that version of LAME produces warbling distortion at bit rates below 192 kbps. But so far, Audacity will accept that 3.97 version above. It's nothing to do with the version, but something to do with how it was built.
Let us know how you get on.
