Metadata Editor in Export Multiple
pnumoman
Post by pnumoman » Sun Oct 11, 2009 10:20 pm
Hello, I have a question about FLAC metadata and Audacity.
I am converting FLAC files to mp3, and my FLAC files have accurate metadata I would like to keep. However, the problem comes from Audacity using the file name, as opposed to the track title, for the track name. Furthermore, Audacity is appending the number 1 to the end of all of these track names; consequently, whenever I try to use export multiple, I have to re-type the track title information so as to change it from the file name to the track title, and also remove the 1 suffix.
Oddly, when I use the metadata editor before export, (file>open metadata editor) the metadata is perfect. Furthermore, when I open files individually, exporting uses the proper metadata. However, even when I have one file per window, the track name has the same problem. It is simply that the single export option (file>export...) seems to use the metadata; export multiple seems to be using the internal, Audacity track name field as opposed to the metadata's track name.
Am I converting multiple FLAC files to mp3 improperly? Is there a setting where I can adjust the behavior of how Audacity sets its track names, to make it use the metadata's track title instead? Is this a bug?
Any feedback would be appreciated. Thank you in advance.
Re: Metadata Editor in Export Multiple
Post by steve » Mon Oct 12, 2009 1:13 am
I've not tested this problem, but Audacity is not a particularly good tool for transcoding files (not what it was designed for). Have you tried Foobar2000? (it's free).
pnumoman
Post by pnumoman » Mon Oct 12, 2009 1:21 am
Thank you for the suggestion; I'll go try that program for my transcoding. I mainly use audacity to cut up concert files into discrete tracks, so it isn't that big of a deal. That said, thanks for replying quickly.
Post by steve » Mon Oct 12, 2009 1:25 am
Foobar2000 is also one of the best audio players available for Windows - it plays almost all known audio file types and is on my "recommended list" ;)
