Ah yes, so it does - and that explains why waxcylinder saw the behaviour persist in 1.3.10 as it would have been using the same audacity.cfg file as his 1.3.9 installation, whereas I did not see the behaviour in a fresh install (with a new .cfg file).Gale Andrews wrote:Audacity will only record into the selection region and stop recording when it reaches the end of the selection if "Play other tracks while recording new one" is enabled in Preferences (also done by enabling "Overdub" in the Transport menu in 1.3.9).
What I don't see, is why continuing recording past the selected region would be desirable in any situation. As a (currently) undocumented feature I think it is confusing that selecting "overdub" should change this behaviour as there is to my mind no obvious connection of why it should do so.
More of a mention than a discussion from what I have found (may 2007 http://n2.nabble.com/Is-recording-suppo ... 53658.html )Gale Andrews wrote:I think this may even have been discussed before long ago on -devel
If this behaviour is intended, then does anyone know why? If it is unintentional, then it should perhaps be recognised as a bug, even if not a very serious or important one, (and I agree that it is not sufficiently important to hold up the release of 2.0).
