How do I make audacity not records all sounds
thegreatbuddha15
Post by thegreatbuddha15 » Sun Oct 04, 2009 8:52 am
After I installed Audacity, every sound recording program i have records all sound from my computer, music on youtube, Windows noises and the mic.
At first I thought it was just audacity, and i fiddled with all the options for a while, but then i realized it was every sound program I have I dont know if audacity changed something but i tried uninstalling it and the problem remained
As far as i know I didnt change anything, I was just trying to layer some of my vocals and someone told me to try audacity
I really love audacity because of all the tools and features and how easy it is to use
but now its impossible for me to get isolated tracks with anything
If it helps im using audacity version 1.3.9 and im on windows xp
Re: How do I make audacity not records all sounds
Post by Gale Andrews » Thu Oct 08, 2009 12:40 am
thegreatbuddha15 wrote:After I installed Audacity, every sound recording program i have records all sound from my computer, music on youtube, Windows noises and the mic. At first I thought it was just audacity, and i fiddled with all the options for a while, but then i realized it was every sound program I have... If it helps im using audacity version 1.3.9 and im on windows xp
Exit Audacity, go to the system mixer, and set the recording input to your microphone (or to line-in if your mic is plugged into a mixer or pre-amplifer), not to stereo mix or similar. Also see this FAQ.
thegreatbuddha15
Post by thegreatbuddha15 » Fri Oct 23, 2009 1:41 pm
thanks gale i love you :]
also any ideas why this happened, im 100% sure i didn't change the stereo mix setting
Post by kozikowski » Fri Oct 23, 2009 9:24 pm
It can get changed "for you." Did you put Skype on your machine?
thegreatbuddha15
Post by thegreatbuddha15 » Tue Oct 27, 2009 5:28 pm
Never installed skype, although my pc does seem to have a virus (i get automatically redirected to weird ad sites even reputable sites)
so that may have something to do with it, but the stereo mix solution fixed my immediate problem so thank you again
