PROGRAM APPEARS TO RUN IN SAFE MODE
cfarnum
Post by cfarnum » Wed Sep 30, 2009 12:39 am
I would like to know why when I run Audacity It appears to run in the safe mode. The icons are green in color and appear to have half moons around them, also when you go to the start menu it appears distorted. I know I went to the properties and changed the 32 bit. It changes the color, but the format for the play, pause, record etc. are not like they are suppossed to be when the program was installed. I also removed the program and re-installed it again, and it is still doing the same thing.
jademan
Forum Crew
Re: PROGRAM APPEARS TO RUN IN SAFE MODE
Post by jademan » Thu Oct 22, 2009 5:05 am
cfarnum wrote:... the format for the play, pause, record etc. are not like they are suppossed to be when the program was installed.
cfarnum,
Can you send us a screenshot? Also, tell us what version of Audacity are you running. And what is your operating system?
cfarnum wrote: I know I went to the properties and changed the 32 bit. It changes the color,
I'm not sure I know what you are talking about. What happens when you change this back?
cfarnum wrote:I also removed the program and re-installed it again, and it is still doing the same thing.
Sometimes it can be helpful to reset your preferences. To do this, follow the directions here. Make sure you put the line 'NewPrefsInitialized=1' in your .cfg file.
I hope this helps.
