Kizzume, I'm not sure this is going to help, but if you noticed this post, another user has a similar issue to you (low volume in mono recording in 1.3.11) which does not occur in the earlier 1.2.6 version of Audacity. Could you try 1.2.6 and see what happens when recording in mono, and whether the recording devices offered are stereo pairs?Kizzume wrote:Here's what the problem is:
Programs like Renoise, ProTools, Cubase, etc., can handle inputs INDIVIDUALLY. Audacity does not. Audacity handles "mono" as a cross between both channels, it does not give one the choice to select only one of those channels. The reason why it is at half volume is that if both channels were recording at full volume and it did NOT count each channel as half-volume, it would cause distortion.
The workaround is to record in stereo, split the channel into two, delete the empty channel, and convert the left side to mono.
The actual fix is simple: Audacity needs an option to record single channels instead of automatically grouping them together.
Thanks
