An Audio problem when using mp3 in both camtasia and WMM
nikkib74
Post by nikkib74 » Thu Sep 24, 2009 9:45 pm
Hi,
I'm sorry to trouble you but I have been searching all over the Internet for hours for solutions and I'm on the verge of tears and my wine is empty!
Basically what I want to do is this,
I want to put a narration to a powerpoint but I want to record my narration with audacity and then edit it in Camtasia byy bringing the slides in adropping them in the right places. I figured it would be easy and it seems to be other than whenever I play back the audio in mp3 format or wav - it's silent.
So - I tested some stuff - I tried to do the same in Windows Movie maker and the same thing happened - so I thought maybe the file was corrupt, but it played back fine in my HP media centre - so it was there.
So I did the same thing again, only this time I just recorded a few seconds of some (potty mouthed) language, saved it as both mp3 and wav and this impoted fine into both windows and camtasia. So - be a glutton for punishment - I re-recorded my longer narrative and saved in both formats - only to find the same thing happened again.#
So - after about 6 hours of too-ing and fro-ing - downloading codecs for windows and various mp3 convertery things - I am going insane - but have come to a slight conclusion :ugeek: I think it's entirly down to the length of the recordings. So... how do I get to record my narration (whic is only about 2.5 mins) and not have it just come up as blank (no wavy sounds lines or anything) when I export it into either cantasia or windows movie maker.
I really hope one of you guys can help me, I'm on a deadline for monday to get some tutorials done - I just never figured that something so simple would take up so much time.
many thanks in advance
nikki
:) whi is actually far more :( right now
Re: An Audio problem when using mp3 in both camtasia and WMM
Post by kozikowski » Fri Sep 25, 2009 12:53 am
Audacity defaults to 32-bit floating for its WAV & MP3 file production. That can cause problems. See what happens when you change the Audacity Preferences to 44100, 16-bit Stereo. Restart Audacity.
You can change your other songs to 16-bit.
Here's a piece from earlier about conversions.
http://forum.audacityteam.org/viewtopic ... 11&t=10190
nikkib74
Post by nikkib74 » Fri Sep 25, 2009 1:36 pm
Thanks very much for your help - changing it to 16bit has solved the problem :) Am now racing through the tutorials and will hopefully beat the deadline,
Nikki
Post by kozikowski » Fri Sep 25, 2009 8:32 pm
I found this the first time a voice performer posted that her audition performance failed to play on a client's computer. I downloaded it and converted it from a 32-bit floating base to 16 and then reposted it. Everyone could play the work and she succeeded in getting the job.
Everybody wins.
