Audacity 1.3.8 compatibility with 64-bit Windows?
ignatz
Post by ignatz » Sat Aug 15, 2009 3:58 am
I have just installed the 64-bit version of Windows 7 in a separate partition as a test system.
I then installed Audacity 1.3.8. Before the application actually appeared on screen, I got this error message:
Audacity error on first run: failed to load shared library C:program files (x86)Windows photo viewerimagingengine.dll (error 126, the specified module could not be found).
I went past the error and briefly used a few effects as a test on a random mp3 and it seemed to work ok, although I did not save and listen to playback.
Questions:
What are the known issues with any version of Audacity and Windows 7 64-bit, or for that matter Vista 64-bit?
What is the significance of the above error over the longer term?
waxcylinder
Re: Audacity 1.3.8 compatibility with 64-bit Windows?
Post by waxcylinder » Sat Aug 15, 2009 1:17 pm
This page in the Wiki http://wiki.audacityteam.org/index.php? ... own_Issues contains the list of known bugs.
ignatz
Post by ignatz » Sat Aug 15, 2009 1:29 pm
WC:
Thanks for the reply.
That page you linked to doesn't mention 64-bit at all. Can I assume that no one on the development team has tested 64-bit at all, even informally.
The 64-bit DVDs will be included with all retail purchases of Windows 7, which will be released October 22, so I would think this will be of concern to some users quite soon.
waxcylinder
Post by waxcylinder » Sat Aug 15, 2009 1:37 pm
ignatz,
it is quite a possibilty that that is indeed the case. The development team is fairly small, there is only one MAC developr for example, so it is quite possible that Audacity has not been tested in the envirinment you have.
Can I suggest that you report your bug directly to the developers. This page in the Wiki tells youu how to report bugs http://audacityteam.org/contact/
The developers do sometimes visit the forum - and in particular I know that Gale Andrews visits fairly regularly to trawl for bugs, as the developers are trying to tease out as many bugs as possible before moving to the next "Stable Release" 2.0 later this year.
Your feedback to the developers will be welcome. We, the Beta users, are effectively a large part of the testing team. That is the point of beta releases.
ignatz
Post by ignatz » Sat Aug 15, 2009 2:13 pm
WC:
Thanks again.
I am now just testing 64 bit on a separate partition to see how many of my 35 or so applications will perform well enough on it. I am not committed to it after the next month or so.
When Windows 7 is released in October, I will install the 32-bit version unless I am confident at that time that all my apps will work on 64-bit. There is nothing about 64-bit that makes it mandatory for me, but I guess it is the future and will become more and more prominent over the next couple of years. Eventually, we will be forced into it, but that may be quite a while.
For all I know, Audacity will work OK, but I did get the noted error when on the first run. What it means, I have no idea.
waxcylinder
Post by waxcylinder » Sat Aug 15, 2009 6:30 pm
Thanks for the update Ignatz - BTW do I assume from your login id that you are a Krazy Kat fan?
ignatz
Post by ignatz » Sat Aug 15, 2009 8:18 pm
Yeah, that would be correct, although I haven't read Krazy Kat in decades--nor Pogo, another of my favorites. Too caught up in music and these god-forsaken computers.
buckeyeman1
Post by buckeyeman1 » Sun Aug 16, 2009 1:00 am
Audacity 1.3.8 beta Unicode will not start up properly on WIN XP x64 SP2. The following error messages occurs during startup from the desktop icon:
Error window:
Audacity Error
Failed to load shared library 'C:Program Files (x86)NetMeetingnmwb.dll' (error 126: the specified module could not be found.)
An expansion of the Details:
20:21:55: Failed to load shared library 'C:Program Files (x86)AdobeReader 9.0ReaderAcrofx32.dll' (error 126: the specified module could not be found.)
20:21:55: Failed to load shared library 'C:Program Files (x86)AdobeReader 9.0ReaderAcroRd32.dll' (error 126: the specified module could not be found.)
20:21:56: Failed to load shared library 'C:Program Files (x86)AdobeReader 9.0Readericucnv36.dll' (error 126: the specified module could not be found.)
20:21:56: Failed to load shared library 'C:Program Files (x86)AdobeReader 9.0Readerlogsession.dll' (error 126: the specified module could not be found.)
20:21:57: Failed to load shared library 'C:Program Files (x86)ASUSAASP1.00.46PowNap.dll' (error 126: the specified module could not be found.)
20:21:58: Failed to load shared library 'C:Program Files (x86)ASUSPC Probe IIAsMultiLang.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
20:21:58: Failed to load shared library 'C:Program Files (x86)ASUSPC Probe IImfc42d.dll' (error 126: the specified module could not be found.)
20:21:58: Failed to load shared library 'C:Program Files (x86)ATI TechnologiesATI.ACECore-Implementation64dshelp64.dll' (error 193: unknown error c1)
20:22:01: Failed to load shared library 'C:Program Files (x86)ATI TechnologiesATI.ACECore-Staticatiacm64.dll' (error 193: unknown error c1)
20:22:01: Failed to load shared library 'C:Program Files (x86)ATI TechnologiesATI.ACECore-Staticatiama64.dll' (error 193: unknown error c1)
20:22:11: Failed to load shared library 'C:Program Files (x86)Audacity 1.3 Beta (Unicode)Modulesmod-script-pipe.dll' (error 14001: this application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.)
20:22:13: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedMODI12.0THOCRAPI.DLL' (error 126: the specified module could not be found.)
20:22:13: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedMODI12.0TWCUTCHR.DLL' (error 126: the specified module could not be found.)
20:22:13: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedMODI12.0TWCUTLIN.DLL' (error 126: the specified module could not be found.)
20:22:14: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedMODI12.0XPAGE3C.DLL' (error 126: the specified module could not be found.)
20:22:14: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedOFFICE12ACEEXCH.DLL' (error 126: the specified module could not be found.)
20:22:15: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedOFFICE12ACELTS.DLL' (error 126: the specified module could not be found.)
20:22:15: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedOFFICE12ACEODDBS.DLL' (error 126: the specified module could not be found.)
20:22:15: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedOFFICE12ACEODEXL.DLL' (error 126: the specified module could not be found.)
20:22:15: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedOFFICE12ACEODPDX.DLL' (error 126: the specified module could not be found.)
20:22:15: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedOFFICE12ACEODTXT.DLL' (error 126: the specified module could not be found.)
20:22:15: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedOFFICE12ACERCLR.DLL' (error 126: the specified module could not be found.)
20:22:19: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedTextConvWPEQU532.DLL' (error 1114: a dynamic link library (DLL) initialization routine failed.)
20:22:19: Failed to load shared library 'C:Program Files (x86)Common FilesMicrosoft SharedWeb Server Extensions40BINFP4AWEC.DLL' (error 126: the specified module could not be found.)
20:22:20: Failed to load shared library 'C:Program Files (x86)Common FilesSystemOle DBmsdaora.dll' (error 126: the specified module could not be found.)
20:22:20: Failed to load shared library 'C:Program Files (x86)Common FilesSystemOle DBmsdasql.dll' (error 126: the specified module could not be found.)
20:22:20: Failed to load shared library 'C:Program Files (x86)Common FilesSystemOle DBMSDMENG.DLL' (error 126: the specified module could not be found.)
20:22:21: Failed to load shared library 'C:Program Files (x86)Common FilesSystemOle DBMSOLUI80.DLL' (error 126: the specified module could not be found.)
20:22:22: Failed to load shared library 'C:Program Files (x86)Common FilesSystemOle DBsqloledb.dll' (error 126: the specified module could not be found.)
20:22:22: Failed to load shared library 'C:Program Files (x86)Common FilesSystemOle DBsqlxmlx.dll' (error 126: the specified module could not be found.)
20:22:22: Failed to load shared library 'C:Program Files (x86)Internet ExplorerConnection Wizardicwhelp.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
20:22:22: Failed to load shared library 'C:Program Files (x86)MarvellCPAInfpu.dll' (error 193: unknown error c1)
20:22:22: Failed to load shared library 'C:Program Files (x86)MarvellCPAsklagg.dll' (error 193: unknown error c1)
20:22:22: Failed to load shared library 'C:Program Files (x86)MarvellCPAy51x64v.dll' (error 193: unknown error c1)
20:22:24: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12OneNoteMSONPMON.DLL' (error 193: unknown error c1)
20:22:24: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12OneNoteMSONPPPR.DLL' (error 193: unknown error c1)
20:22:24: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12IPEDITOR.DLL' (error 126: the specified module could not be found.)
20:22:25: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12OISAPP.DLL' (error 126: the specified module could not be found.)
20:22:26: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12PPCORE.DLL' (error 126: the specified module could not be found.)
20:22:26: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12PSRCH.DLL' (error 126: the specified module could not be found.)
20:22:27: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12Wordcnv.dll' (error 126: the specified module could not be found.)
20:22:27: Failed to load shared library 'C:Program Files (x86)Microsoft OfficeOffice12WWLIB.DLL' (error 126: the specified module could not be found.)
20:22:27: Failed to load shared library 'C:Program Files (x86)Microsoft Workslfbmp13n.dll' (error 126: the specified module could not be found.)
20:22:27: Failed to load shared library 'C:Program Files (x86)Microsoft WorksLFCMP13n.DLL' (error 126: the specified module could not be found.)
20:22:27: Failed to load shared library 'C:Program Files (x86)Microsoft Workslfgif13n.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Microsoft WorksLfpng13n.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Microsoft WorksLfwmf13n.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Microsoft WorksLTDIS13n.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Microsoft Worksltfil13n.DLL' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Microsoft Worksltimg13n.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Microsoft WorksWkImg90.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Microsoft WorksWkWat90.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxcomponentsbrowserdirprovider.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxcomponentsbrwsrcmp.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla FirefoxAccessibleMarshal.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxfreebl3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxjs3250.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxnspr4.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxnss3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxnssckbi.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxnssdbm3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxnssutil3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxplc4.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxplds4.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxsmime3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxsoftokn3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxsqlite3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxssl3.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxxpcom.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)Mozilla Firefoxxul.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowsbckg.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowschkr.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowsCmnclim.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowshrtz.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowsrvse.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowsshvl.dll' (error 126: the specified module could not be found.)
20:22:28: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowsZCorem.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowsZNetM.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowszoneclim.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)MSN Gaming ZoneWindowszonelibM.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingh323cc.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingnac.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingnmas.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingnmchat.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingnmcom.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingnmft.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingnmoldwb.dll' (error 126: the specified module could not be found.)
20:22:29: Failed to load shared library 'C:Program Files (x86)NetMeetingnmwb.dll' (error 126: the specified module could not be found.)
1.3.7 runs fine on this system.
I also forwarded this to the [email protected] email.
BG
