LAME file
Feather
LAME file
Post by Feather » Wed Jul 01, 2009 12:44 pm
To encode MP3's you are supposed to unzip the LAME file first. The file is in exe format, there is nothing to unzip as far as I can see. So far I do not see a way to save as MP3, there isn't an option to do so in the newer version. Could someone make this a bit clearer than mud? Thanks:)
Re: LAME file
Post by steve » Wed Jul 01, 2009 4:37 pm
The exe file is a self extracting archive. Double click on it to run it and it will create a directory in your Program Files folder called "Lame for Audacity" and place the contents (Lame encoder) inside.
