not enough room available to paste the selection
sagetyrtle
Post by sagetyrtle » Thu May 28, 2009 9:42 am
I'm using 1.3.7, Windows XP.
In previous versions, I was able to paste a selection and the track in front of it would jump forward.
Now I get the error message: "There is not enough room available to paste the selection." I understand why it's happening, and how to paste the selection in.
My question is: is there a preference I can set so that the track *does* jump forward, the way it did before?
Thanks much for any suggestions you might have,
-Sage
waxcylinder
Re: not enough room available to paste the selection
Post by waxcylinder » Thu May 28, 2009 9:45 am
This sounds like it may be a bug - I will notify one of the developers.
Post by Gale Andrews » Thu May 28, 2009 10:03 pm
Go to the Interface tab of Preferences and under "Behaviors", put a check mark by "Editing a clip can move other clips". It is on by default, so you must have unchecked it.
sagetyrtle
Post by sagetyrtle » Sat May 30, 2009 10:45 pm
Gale -
Hurrah! You were absolutely right. Thanks very much.
-Sage
