Does 1.3.7 allow?
Narayan
Does 1.3.7 allow?
Post by Narayan » Wed May 27, 2009 12:48 pm
Does the new version allow you to monitor(listen to) the tracks you have already recorded while you record new parts.
IE. so I can make bass guitar parts time in with the pre-recorded normal guitar parts properly?
Re: Does 1.3.7 allow?
Post by kozikowski » Wed May 27, 2009 1:53 pm
I think they will both do that. Audacity Preferences > Audio I/O > 'Play tracks while recording new ones.' You may need to mess around inside the Windows Control Panels a bit, too.
You're very next posting is going to be, "How can I avoid the delay when the track plays?" That's called latency and you can adjust that in the same pane.
