possible bug - can only record at 96000
ad1940
Post by ad1940 » Tue May 26, 2009 12:51 pm
Hi… I’m a long-time Audacity user who has suddenly run into a very strange bug.
Details:
- running v 1.37 on win xp sp 2
- I can only record when my sample rate is set 96000 hz. Up until a week ago this never mattered, but now if the sample rate is anything other than 96000 I can’t record (time line just stays stuck at 0).
Any thoughts on what may be going on?
Thx much,
AD
waxcylinder
Re: possible bug - can only record at 96000
Post by waxcylinder » Tue May 26, 2009 1:09 pm
What I would do is try deleting your Audacity configuration file which is where Audacity stores your preferences. You can find it in C:Documents and Settings<your_user_name>Application DataAudacityaudacity.cfg
Audacity will create a new cfg file when you restart it - note that this will reset all your preferences - so in particular it will revert to mono recording - so these will need to be reset.
ad1940
Post by ad1940 » Thu May 28, 2009 3:23 pm
waxcylinder wrote:What I would do is try deleting your Audacity configuration file which is where Audacity stores your preferences. You can find it in C:Documents and Settings<your_user_name>Application DataAudacityaudacity.cfg
Thx, but no luck... deleted config, but still no recording at anything other than 96000???
Post by kozikowski » Fri May 29, 2009 12:15 am
What are you trying to record? People always start the movie after the second act.
When you restarted Audacity after the Great Deletion, did it ask you "English?" at First Birthday? If it didn't, then you're still sitting on your old config files.
