Uli wrote:I load a track of about 2 minutes length. I see the stripes and I know nothing. Waiting for 10 minutes to allow the display calculation ends in - stripes. Nothing else.
OK so it's not a nice feature for you - but that's because, for some reason, it is not working correctly. A 2 minute files should open fully (and display the waveform) very quickly (no more than a couple of seconds, unless you are using an extremely old and slow machine).
The lack of documentation about this feature is because it is a new feature and there is a shortage of volunteers to complete the documentation (volunteers are always welcome). However there is a mention of it in the manual:
http://audacityteam.org/manual/index.ph ... nd_Loading
Unfortunately, this documentation seems to be a bit out of date now as in the current version of Audacity there seems to be no way to switch this feature off.
The "On-Demand-Loading" feature has been around for a good few months now, and this is the first post that I have seen where someone is having a problem with it - so there you go - you are special
Probably the best thing is to see if we can quickly fix the problem, and if not, then you could try downgrading to an earlier version.
I think that the most likely cause of the problem is that the Audacity configuration file has got messed up when upgrading from 1.2.4 (but do have a look at that manual page first in case you can spot something obvious that may be causing the problem).
To reset the configuration, you need to find the "audacity.cfg" file - note that it is a hidden file.
The location of the file is:
# Windows (except Vista) : Documents and Settings<user name>Application DataAudacity
# Windows Vista: Users<user name>AppDataRoamingAudacity
Exit Audacity and open audacity.cfg in a text editor, then remove all the content except the line "NewPrefsInitialized=1"
Save the audacity.cfg file and restart Audacity. You should be asked to select the language.
If this does not work, you can download the 1.3.6 version from here - If I remember correctly, this version allows you to switch the feature off, as described in the manual.
http://kent.dl.sourceforge.net/sourcefo ... -1.3.6.exe
