Gain slider versus amplify effect
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Longtrack
Post by Longtrack » Sun Jan 22, 2012 4:09 pm
Just curious if the technology applied by the gain slider is in principle the same as applying permanent amplification with Amplify form the Effect menu. Is it?
Re: Gain slider versus amplify effect
Post by steve » Sun Jan 22, 2012 5:11 pm
They are slightly different.
When you apply the "Amplify" (or "Normalize") effect, the audio data is changed there and then.
When using the Gain slider, there is no change to the actual audio data at that time. Audacity is just instructed to scale (amplify) the data during playback, mixing or export.
This is why the Gain slider acts immediately whereas the Amplify and Normalize effects take some time to process.
PGA
Post by PGA » Sun Jan 22, 2012 5:28 pm
I suspect that Longtrack was trying to find out whether there would be any audible difference between the two controls as a result of their technology differences. The Gain control obviously affects all parts to the same degree. Does Amplify do the same or does it alter some parts of the sound differently to other parts?
Post by steve » Sun Jan 22, 2012 5:47 pm
PGA wrote:Does Amplify do the same or does it alter some parts of the sound differently to other parts?
The Amplify effect changes all of the selected audio by the same degree. The Selection may be a full track, part of a track, or even multiple tracks.
