Split from http://forum.audacityteam.org/viewtopic ... 15&t=60369 as this topic is not related.
Hi there
Can anyone help with tranporting save Audacity file to another Audacity user - I want to send file via email so as the editing can be carried on by another user and then returned to me
Sending .aup project files to another user
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
- Quality Assurance
Re: Sending .aup project files to another user
Standard Audacity projects must include the uncompressed audio in the project _data folder, which makes them too large to e-mail.
You can send to others as a compressed Audacity project (compressed OGG format, slightly lossy), or to be lossless, export tracks as WAV files, zip them up then send them to a file hosting service. You can also do that for standard Audacity projects, as long as any imported WAV or AIFF files are copied into the project.
Please read:
http://wiki.audacityteam.org/wiki/Sendi ... _to_others
Please read:
Sure, but. You need to send the AUP file and the closely associated _DATA folder with all the actual music in it. You have to also send along all the imported music you used in your show and in the right folders.
You don't need the music step if you elected to include imported music in your Project (_DATA Folder).
File > Check Dependencies.
Audacity > Preferences > Projects > [X] Copy All Audio....
There's a resync command, too, but I don't remember where it is.
Whoever ends up with the files and folders needs to keep them in the same folder or directory for them to work. Also, of course, you all have to have the same version of Audacity and all the same plugins.
