Suddenly won't export multiple
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
polc1954
Post by polc1954 » Wed Aug 17, 2011 8:01 am
I suddenly have a problem with Export Multiple. On my last session I tried to save and got the message " cannot export audio". It will, however, save with export as a single file. I tried saving a previous project that I successfully had saved as export multiple and I got the same message. Any thoughts?
Re: Suddenly won't export multiple
Post by kozikowski » Wed Aug 17, 2011 11:59 am
Sudden, odd computer insanity can be caused by your drive filling up. Is it? How much room do you have and how big is the drive?
polc1954
Post by polc1954 » Wed Aug 17, 2011 4:35 pm
521 GB free of 581
billw58
Post by billw58 » Wed Aug 17, 2011 6:00 pm
At this point we need to know your operating system and exactly where you are trying to save the files. Also, are you using any characters in the labels other than letters, numbers, underscore and dash?
-- Bill
polc1954
Post by polc1954 » Thu Aug 18, 2011 4:37 am
Windows 7 - c:usersnamedocumentsfolder namename 1.wav Names consisted of numbers and letters only. I tried to re-export (multiple) a project I did successfully a couple of days ago and it also would not go past the 1st label. I was, however, able to do an export only on this project. Thanks
polc1954
Post by polc1954 » Thu Aug 18, 2011 10:54 am
Just for fun I re-downloaded Audacity, saved it to a new file, tried to export multiple and got the same results.
Paul
Edgar
Forum Crew
Post by Edgar » Thu Aug 18, 2011 3:33 pm
After an unsuccessful attempt to Export Multiple, open the Audacity Log ( menu item Help > Show Log...); in the log window which should open select menu item Log > Save... and paste the resulting text into a reply here (use the "Code" button so formatting is preserved).
You might also want to reset your configuration: reset the Audacity preferences by editing audacity.cfg as described at http://manual.audacityteam.org/man/Preferences#stored
but please do so after posting the Log.
Just for the sake of having complete information, are you using 64- or 32-bit Win7, have you installed SP1 and if so was it just before the problems started. Also, exactly which version of Audacity are you using (see menu item Help > About Audacity... ) give us the full x.y.zz-a|b version number, build date and configuration (Unicode etc.):
polc1954
Post by polc1954 » Fri Aug 19, 2011 8:55 pm
Using Windows 7 64 bit, always used sp1 with audacity. Don't see any option to save log. Don't understand "code" button
Post by kozikowski » Fri Aug 19, 2011 9:21 pm
It saves itself. Audacity keeps a record of events.
While you have Audacity open, Top Menu Bar > Help > Show Log.
Copy and paste that to this forum. Select "Code" on the forum page because if you don't, our systems might try to make the words look "pretty" and hide or damage some of the information we need.
Edgar
Forum Crew
Post by Edgar » Fri Aug 19, 2011 9:35 pm
After you click "Reply" you will see a row of buttons above the text entry field:
Code: Select all
when you use it the text between the [c o d e] and [/ c o d e ] will not be automatically formatted by the BBS software.
Seeing your Log from before you exit Audacity might really help us help you.
