Unwanted echo
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Pobinr
Unwanted echo
Post by Pobinr » Thu Jul 14, 2011 8:36 am
I've been using my Line 6 toneport for a year or so with no problems using S/PDIF-in.
Until I wanted to record my playing over an MP3 backing track. So I set to 'Record what you hear' .
That caused a horrendous echo feeding back on itself. So I switched back to input of 'S/PDIF-in'. The echo no longer feedsback, but it's still there !
It's about a half second delay added to original sound.
So something's changed when I initially switched from 'S/PDIF-in' to 'what you hear'.
Any ideas ?
thanks
waxcylinder
Re: Unwanted echo
Post by waxcylinder » Thu Jul 14, 2011 9:11 am
turn off the "Software Playthrough" either in Preferences or from the Tracks drop-down menu. If you have this selected while trying to record what is playing on the computer ("what you here", "stereo mix" etc.) you will create a feedback loop (the symptoms you describe).
Pobinr
Re: Unwanted echo
Post by Pobinr » Thu Jul 14, 2011 9:59 am
Somehow software play through got enabled when I switched to what you hear.
Now I've switched it off & no more echo.
Many thanks
