I often use Audacity, mounted on a removable hdd.
But offered for downloading from the site audacity.sourceforge.net version of the program saves the settings on your computer, not on a removable hdd.
Because of this I have to constantly re-tune the program.
I found and downloaded from the site http://portableapps.com/apps/music_vide ... y_portable portable version, it keeps the program settings in the folder of the program.
I installed it on your computer, but Portable Audacity generates an error and the settings are not saved!
I installed Audacity on a removable portable hdd, settings are preserved, but not available in the Russian language program.
Therefore I would like to be able to download from audacity.sourceforge.net fully portable version of Audacity.
Audacity portable.
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
black555cat
billw58
Re: Audacity portable.
You should get Audacity from the official site here: http://audacityteam.org/
If you a create a directory called "Portable Settings" in the same directory as the Audacity executable, the Audacity settings file ("audacity.cfg") will be stored there. This should preserve all your settings, including language.
-- Bill
-- Bill
black555cat
Thank you so much !!!
Everything turned out !!!
