Hi,
Is there a way to set "Project Rate Kz." to default to 11025 all the time so I don't have to select it.
Also, can the export file "save as type" be set to default to "Unsigned 8 bit PCM" ?
I work in this mode 90% of the time and it would save quite a bit of "clicking"
Thanks,
Don.
Defauld settings
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
billw58
Re: Defauld settings
Go Preferences, the Quality section and set the "default sample rate" to 11025.
As for the "save as type", does Audacity not remember the last setting you used?
-- Bill
-- Bill
