Project has opened, but has no sound
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
kt_oneill
Post by kt_oneill » Mon Nov 22, 2010 10:24 pm
After I exported my project as an Mp3, my project would not open and the error said something along the lines of 'could not find project.' After a lot of searching, it eventually did open up but without the sound, making my project look like this:
http://es.tinypic.com/r/fc4e48/7
I also found a new folder on my memory stick titled '_data' for the project.
http://es.tinypic.com/r/4gqfsn/7
Am desperate for a solution or will have to restart 2 and a half months worth of work.
thanks.
bgravato
Operating System: Linux Debian
Re: Project has opened, but has no sound
Post by bgravato » Tue Nov 23, 2010 1:07 am
When you save an audacity project it saves an .aup file and _data folder. The .aup file is just a text file and the audio itself is splitted into several small files inside that _data folder. You should not at any point delete, move or rename any of those. You need both the .aup file and the _data folder to open your project.
Post by steve » Tue Nov 23, 2010 1:33 am
Probably worth having a read through this page on the Audacity wiki: http://wiki.audacityteam.org/wiki/File_Management_Tips
kt_oneill
Post by kt_oneill » Tue Nov 23, 2010 6:42 pm
ahh thank you sooo much, just got my project back, cannot tell you how relieved I am. Great help!
kt.
billw58
Post by billw58 » Tue Nov 23, 2010 6:44 pm
How did you get it back?
-- Bill
kt_oneill
Post by kt_oneill » Tue Nov 23, 2010 8:12 pm
I moved the _data file to the same directory as the audacity file.
