Recording trouble
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
alfgrs
Recording trouble
Post by alfgrs » Tue May 20, 2008 10:02 pm
Hi Buddies,
I can't recording only the other new track, when I try to record the voice, the recording capture the sound of previously track. I set the preference to "play other tracks while recording new one", it's not working. Why can I do to fix it????
My system is Win XP
Thanks.
ALF
Re: Recording trouble
Post by steve » Tue May 20, 2008 11:04 pm
Find the speaker icon in the bottom right of the screen (near the clock) and double click on it. This should bring up a mixer application - usually the WINDOWS MIXER. You need to find the "Record" settings, and switch off "Stereo Mix" as the recording input, and select "Line In" or "Mic In" (whichever you are using) instead.
"Stereo Mix" is sometimes just called "Mix", or "What U Hear".
alfgrs
Post by alfgrs » Wed May 21, 2008 1:46 pm
Hi Steve.
Thanks for your advice, but I tried to do what you said and nothing has changed. I still have the same trouble. If you have another tips I'd like listening to.
See ya.
ALF
alfgrs
Post by alfgrs » Wed May 21, 2008 1:58 pm
Hi Steve, after looking for and got nervous, I found out what was my mistake, I just had to lock the audio track. Now everything is going Ok. See ya.
