Stereo Mix Problem
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
aurelieduval24
Stereo Mix Problem
I have been using the software for a while and I like it. But recently it seems that if I set the input to stereo mix, it doesn't pick up whatever I am recording. This is also true with cd's - setting it to cd does nothing, stereo does nothing. The only thing that picks up a signal is mono mix. Did I accidently set something somewhere that would cause this?
Re: Stereo Mix Problem
I presume that you are making these settings in Audacity?aurelieduval24 wrote:recently it seems that if I set the input to stereo mix, it doesn't pick up whatever I am recording. This is also true with cd's - setting it to cd does nothing,
You probably need to check your sound card "Recording" settings. Have a look in the Windows Control Panel to see which Recording Inputs are enabled.
http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
