I've just gotten audacity, and I'm a bit confused.
I have a WAV file that I've tried to import into audacity,
but when I import the file, it just makes this weird squeaky noise, like a tape recorder being rewound.
I downloaded the off vocal off of my ipod, using a download app, but it is definatly a WAV file, I converted it using the app (I checked the "proporties" on my computer).
Am I doing something wrong? Or is my computer messed up somehow?
I have Windows XP. Please help!
WAV file makes weird noise when imported
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
bigmouth12349
bigmouth12349
Re: WAV file makes weird noise when imported
I tried that, same problem.kozikowski wrote:Open the file, don't Import it.
http://forum.audacityteam.org/viewtopic ... 10#p108306
billw58
It may say it's a WAV file, but WAV is just a container format and can contain just about anything.
Have a look at this topic and see if it helps: http://forum.audacityteam.org/viewtopic ... 10#p108301
-- Bill
-- Bill
bigmouth12349
Thank you! I'll try what's suggested here.
