Converting WMA to WAV
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Donny
Post by Donny » Fri Oct 08, 2010 2:47 pm
I would like to import a file to use as part of a tribute piece but I am not sure how to convert the file from WMA to WAV to Audacity can import it. How hints?? ;)
Re: Converting WMA to WAV
Post by steve » Fri Oct 08, 2010 3:40 pm
If you are using Audacity 1.3.12 and have FFmpeg installed then you may be able to Import the WMA file directly into Audacity, and then Export it as a WAV file.
(see here: http://manual.audacityteam.org/index.ph ... tallffmpeg )
Otherwise, you could use SUPER by erightsoft to do the conversion.
You can probably use Windows Media Player to convert it, but I never use WMP so I'd not know how to do that.
