I agree with whomper here - it could quite quite easily just be another bad pressing.
In the days when I was buying vinyl LPs I can remember with some recordings (even on major labels) having to take them back more than once to finally get a good pressing that played properly.
If your TT is playing other LPs ok then it is far more likely to be a badly pressed or mastered LP at fault.
New Vinyl Getting Skips
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
waxcylinder
Re: New Vinyl Getting Skips
Hmm ok....
It's from Wichita Records - they aren't massive, but certainly not small either - and have been doing this for a while.
Thanks for the advice - I'll make sure the other records still playing correctly then go searching.
new guy mastering
or
pressing for a third party who mastered it badly
they can mess up the playability if they dont master for vinyl
but use a cd approach ala loudness war style mastering
or
