generate clicktrack is rate-dependent in 1.3.x
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
_gc
Post by _gc » Tue Dec 04, 2007 2:17 pm
I have yet to see this corrected in any of the 1.3.x releases: Generate > Click Track only works correctly when the track's samplerate is set to 44.1 kHz. Since I usually work in a 48 kHz project I think that's very annoying.
Seems like an easy thing to fix... In 1.2 you can have any rate and generate a correct click track (time-wise). In 1.3 the same command gives different results (in both pitch and length) for different samplerates.
Re: generate clicktrack is rate-dependent in 1.3.x
Post by steve » Tue Dec 04, 2007 3:34 pm
That's strange - I've got v. 1.3.4 (Linux) and it hasn't got "Click Track" in the Generate menu at all.
Do I need to enable it somehow?
[EDIT] Oops - it's ok, it's in a sub-menu.
Post by steve » Tue Dec 04, 2007 3:47 pm
Well the work-around is trivial enough - just change the sample rate of that track - and it will usually only need doing once per project. But I agree, a fix would be much better than a work-around.
