Cut/Ctrl-X cuts too much
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
RodBarnes
Re: Cut/Ctrl-X cuts too much
Post by RodBarnes » Tue Nov 24, 2009 5:01 pm
This is exactly the behaviour when linking is on and you have a label track.
By "linking" do you mean having the "snap to" enabled? I still do not have that enabled. But I am seeing that if I do not have a label track, I do not see this behavior. (I thought sure I saw it previously even without a label track but I guess I was mistaken; I'm definitely not see it now.)
This conflicts with your previous report of cutting at 2:31.
Oh, good point... :? It must vary depending upon some other factor. The previous notes about examples at 2:31, etc. were from a test with a different imported WAV. The testing I did to try to find where it begins was with a different imported WAV.
I can't reproduce this using 1.3.9.
I can reproduce it consistently in 1.3.9.
Given that I am not able to reproduce what I thought I was seeing without the label track, do you still want the screenshot? Or is this issue related to the label track and a known problem?
billw58
Post by billw58 » Tue Nov 24, 2009 5:09 pm
OK, if you are sure that you do not see the problem when you do not have a label track then this is definitely the linked-tracks-cuts-too-much bug. No screenshot needed.
BTW, by "linking" I mean Tracks (menu) > Link Audio and Label Tracks. This is different from Snap to.
-- Bill
