Hi there
I have a Ion USB tuntable and the software that it ships with doen't yet support version 9 of iTunes.
Can someone please tell me if Audacity supports V9?
Cheers
Orb
iTunes compatability
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
waxcylinder
Re: iTunes compatability
Your question doesn't really make sense.
ION ships its TTs with (amongst other software) Audacity 1.2.x (I would recommend upgrading, for free to 1.3.9 from http://audacityteam.org/download/
Adacity neither "supports" nor "doesn't support" iTunes. Audacity is a recording and editing tool - after a recording has been made it can be exported to a number of audio file formats: WAV (uncompressed and large), MP3 (smaller by a factor of 10 - compressed), Ogg, FLAC etc.
ITunes can import MP3 files or WAV files (if you use WAV your iPod will fill up quickly) - if you want to get tricksy you can get iTunes to convert WAV files to Apple's own AAC compressed format.
I would recommend a read of the following tutorials from the Audacity Wiki:
http://wiki.audacityteam.org/index.php? ... uter_or_CD
http://wiki.audacityteam.org/index.php? ... ate_tracks
http://wiki.audacityteam.org/index.php? ... s_and_iPod
Hi there
Maybe I should be more specific.
I bought a Ion TT, installed the software it shipped with (EZ Vinyl convertor) and it all worked fine.
Downloaded V9 of iTunes, went to record another piece of vinyl and I'm getting an error pop up saying that it requires iTunes to be loaded in order to work - so I guess it's not recognising the new version even though it is installed and working fine.
Ion suggested using audacity - hence how I got here.
What do you think would be the best fix for this problem?
Cheers
Orb
Cheers
Orb
billw58
What''s the problem? Ion seems to suggest that Easy Vinyl Convertor won't work and that you should use Audacity instead. Now you've got Audacity. Problem solved.Orb wrote:Ion suggested using audacity - hence how I got here.
Orb
I'll bet Easy Vinyl was using iTunes for MP3 conversion, or had some feature where it would export directly to your iTunes library.
If you don't have Audacity yet, go here: http://audacityteam.org/ and click on the download link for your OS.
To make MP3s with Audacity you'll need the LAME MP3 encoder. Go here: http://audacityteam.org/help/faq?s=inst ... m=lame-mp3
To learn how to use Audacity, go here: http://manual.audacityteam.org/index.ph ... =Main_Page
-- Bill
Bill - you sir are a star
Thanks a lot - cheerio
Orb
Orb
