There are several downloads for lamefile . Which do I use for free that will work for audacity to playback audio info.
T hanks,
Don G.
lamefile download
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
dlgilbert1
Re: lamefile download
dlgilbert1,dlgilbert1 wrote:There are several downloads for lamefile . Which do I use for free ...
It depends on your operating system. Go to http://lame.buanzo.com.ar/ and read the fine print.
If you are on Windows, for example, you will need Lame_v3.98.2_for_Audacity_on_Windows.exe. Run this to create your .dll file.
However, I think lame is used to encode (store), not to decode (play) audio info.dlgilbert1 wrote:... that will work for audacity to playback audio info.
I hope this helps.
